- 12 Juli 2021
- 900
- 874
- Pro2/g30/Legend
Hier eine Liste der Fehlercodes direkt von Kaabo
Code | 报错内容 | Error meaningresolvent
E06 | 电池欠压 | Battery undervoltageFirst fully charge the scooter
E07 | 电机故障 | Motor issueCheck the motor cable whether is loose
E08 | 转把故障 | Brake bar issueCheck the cable of the display and main wire and the core pin inside the display wire port for bending
E09 | 控制器故障 | Controller issueCheck the connection of controller or replace the new controller for onspection
E10 | 通信接收故障 | Electric system communication reception faultCheck the cable of the display and main wire and the core pin inside the display wire port for bending; Check connection between the controller and the main wir
