HIER ENTLANG:
PUNKT [33] - Fehlercodes - Errorcodes auslesen inkl. Lösungsbeiträgen
rollerplausch.com
ALT:
Dachte mir ich stell das hier mal sauber auf zum schnell nachschlagen, kommen ja doch immer wieder die gleichen Fragen im Telegram.
RP ✔️ - To-do-Liste 🛠️ Ninebot G30, G30D II 2 E-Scooter (Wartungstipps & Fehlerbehebung)
To-do-Liste & Tuning-Anleitungen von RollerPlausch.com 📌 Diese Infos basieren auf den Ninebot MAX /Seat/Audi G30/D II E-Scooter aus der RollerPlausch-Community. Vieles kann hier plattformübergreifend auch auf G30Lx, Ninebot F-Serie, die Ex-Serie angewandt werden. Weitere To-Do Listen haben...
ALT:
Fehlercode | Beschreibung | Betroffene Teile |
10 | Communication between Dashboard and Control Board is Abnormal, Please check the related connections | Dashboard, Control Board |
11 | Wheel Hub Motor A Phase Current sampling is Abnormal, please check the main Control Board | Control Board |
12 | Wheel Hub Motor B Phase Current sampling is Abnormal, please check the main Control Board | Control Board |
13 | Wheel Hub Motor C Phase Current sampling is Abnormal, please check the main Control Board | Control Board |
14 | Throttle Hall is abnormal, please check the Throttle Switch, Dashboard & related Connections | Dashboard, Electric Throttle |
15 | Brake Hall is abnormal, please check the Throttle Switch, Dashboard & related Connections | Dashboard, Brake lever |
18 | Wheel Hub Motor Hall is abnormal , Please check the Motor, Control Board & related connections | Control Board, wheel Hub Motor |
19 | Battery Voltage detection is abnormal, Please check the Battery, Control Board and related connections | Control Board, wheel Hub Motor |
21 | Battery Communication Error, Please check the Battery, Control Board & related connections | Battery |
22 | Battery Password Error, Please replace the Battery | Battery |
23 | Battery Default Serial Number, Please Replace the Battery | Battery |
24 | System Voltage detection is abnormal, Please check the Control Board | Control Board, Battery |
26 | Flash Stroge Error, Please check the Control Board | Control Board |
27 | Control Board Password Error, Please replace the Control Board | Control Board |
28 | Motor MOS driver upper Bridge is short circuited, Please check the Control Board | Control Board |
29 | Motor MOS driver Lower Bridge Error, Please check the Control | Control Board |
31 | Program Skip Error, Please check the Control Board | Control Board |
35 | Vehicle Default Serial Number, Please replace the Control Board | Control Board |
39 | Internal Battery Temperature Sensor is abnormal. Please replace the Battery. | Battery |
40 | Control Board Temperature Sensor is abnormal. Please check the Control Board. | Control Board, Battery |
