Hi,
1.
The Flipsky 75100 (Vesc Clone) uses 6* MDP10N027 MosFETs and it is rated to 20S and 100A, so maybe a very good choice if available.
You have to solder the traces stronger too!
2.
If the battery voltage is above 60V you have to do a trace cut to the first step down and supply it with a voltage below 60V. No, I don't know the exact location. I think it should be near the capacitor in the next picture.
3.
You have to change the resistor of the battery voltage divider to get a voltage at the output below 3V3 at full battery. No, I don't know the position. This should be the right, but I didn't test it:
12D (120.000k) and 10k is about 43V.
27D (270.000k) and 10 will give about 92 V.
You habe to setup the ADC Value in the firmware!
4.
You have to change the big capacitors, but it looks, you're always doing this.
If you find a solution for 2&3 please give me a short feedback, I would like to have this information for my knowledge. Thanks!
