I messed up my 1s, would appreciate any help
24 August 2020
Mi scooter 1S
At first, sorry for english post, but this is best escooter forum online and i am really desperate.
So .. i messed up.
I bought replacement dashboard for my 1s. It has BLE 9.1.0 so its clone/fake. In every app it shows up as m365 pro. I opened ** Bezahlsoftware ** and select "return to Stock firmware". It flashed me with ESC 1.5.5 (stock for m365 pro) and BMS stayed 1.2.8 (Stock for 1S).
So now i have my 1s which shows up as m365 pro with clone BLE m365 pro ESC and 1s BMS. Scooter is sometimes tuning itself on and off. (i am surprised it isnt bricked yet..) Any solutions what should i do? I do not even need "better" firmware, i would be happy with just stock now, but i dont know which versions of these 3 softwares should i flash to scooter to function properly... Everything from 1s, or everything from pro, or even from pro2? (Cause i red 1s and pro2 are almost similar in software). Is it even possible and safe to reflash ble 910 with 0.90 from m365 pro?
I know i messed up many many times. If there is possibility to give my scooter proper function i would really appreciate any help guys.
And my advice .. dont buy fake dashboard if you wanna flash your scooter, or if you do, know what your are doing, not like me .. :/
Thank you! :)
Or it would be perfect if someone could translate this into German, and post it again (cause i know i am not supposed to post in english). Maybe moderator? Thank you very much.
The easiest way would be to get an original Dashboard for a G30 / Pro2 or 1S and flash it with original Firmware via ST-Link. At least that's what I think should work. AFAIK the new Dashboards are interchangeable Hardware wise, just the "default software" from factory is different according to the replacement part number. So a G30-Dash works with a 1S, after flashing the correct BIN-File from files.scooterhacking.org
I don't know if it is possible to get OEM-Firmware running on a bad clone, at least I don't think it is...
Check the Scooterhacking.org Discord server for the best English-speaking community.
Reaktionen: Noel
Additional to what Doragonnaito42 Doragonnaito42 said, these clone dashboards usually can be flashed via ST-Link with the stock BLE. It is worth to give it a try, since ST-Link Adapters are quite cheap.
