- 18 September 2021
- 9
- 3
- Segway max G30 audi
Hi guys and girls!
my german is not good enough to write what i'm going trough
but here it goes.
I recently bought a G30 to fix for my girlfriend.
The 'problem' was the internal charger that was fucked... at least they said this.
After quite some testing , i came to the conclusion that the input port of the bms is broken ? deffective chip? i don't know...
when i hook it up to the outgoing power cable (to controller) i can fully charge the battery...
the led light blinks red , and when it's full it's stable non blinking blue...
My question is , is the entire bms ready for the garbage can? or can i fix this little chip?
Second can i just make a connection to a plug , and charge it with an external 42volt charger? ( connected with the Fat outgoing wires to the controller)
The thin wires do nothing when connected....
I've read alot about not being a good way to charge it.. because it's not balanced charging....
But here on the forum i've read that the bms balances when the current goes out , and not in?.... is this correct?..
The bms does it's job , and also the communication to the controller and display works...
All help / advice is welcome!
German or english
THaaaaanks!
Morph
German or english
THaaaaanks!
Morph
