Scooter hacking utility 1.4
21 August 2021
289
180
Pro2 und Max 30 G
Hallo, wer benutzt die 1.4 auch? Wie habt Ihreure Kurven für Sport und Bremse konfiguriert?
Die SHU wird ja gerade von Grund auf erneuert. Die aktuell verfügbare Version im Google PlayStore ist die v1.3 vom 20. Juli 2021.
Die Betatests der SHU v2.0-rc4 feat. SHFW RC6 laufen aber bereits auf Hochtouren!
SHFW RC6 changelog:
- Fixed displayed temperature for Xiaomi ESC and emulated BMS
- Improved CamiBLE compat
- Softened start if motor start speed is below 2km/h
- If you don't use adjustable CC, tapping the throttle will disable CC (just like Ninebot firmware)
- Added "current raising" for speed based throttle (called current smoothness in app)
- Added customizable beep when disengaging CC
- Fixed some issues if CC delay was 0 (when settings were carried over from previous RC install)
- Fixed default wheel size for E series
Please make sure you have a current raising coefficient set before using speed-based controls. I recommend wiping your settings between each RC!
App RC4 changelog:
- Prevented ESx/E users from selecting extra long beep (doesn't exist on those platforms)
- Prevented CamiBLE users from changing dash display options
- Added new controls for platform specific temperature sensors, cruise control off beep and current raising
- Prevented smooth brains from using speed-based throttle without a speed limit set (smh)
- Show when spoofed legacy CFW is detected
- Added the contributions list (finally)
- Fixed general I/O stability (that "Index data error" when flashing ends should be gone)
- Better checks to ensure SHFW is actually installed after flashing
- Fixed automation that would trigger anytime you'd visit the Info tab
- Automatically switch to info tab after flashing (that way SHFW tab switch isn't buggy anymore lmao)
- Added tooltip bubbles to the app (including SHFW)
