SHFW RC6 changelog:
- Fixed displayed temperature for Xiaomi ESC and emulated BMS
- Improved CamiBLE compat
- Softened start if motor start speed is below 2km/h
- If you don't use adjustable CC, tapping the throttle will disable CC (just like Ninebot firmware)
- Added "current raising" for speed based throttle (called current smoothness in app)
- Added customizable beep when disengaging CC
- Fixed some issues if CC delay was 0 (when settings were carried over from previous RC install)
- Fixed default wheel size for E series
Please make sure you have a current raising coefficient set before using speed-based controls. I recommend wiping your settings between each RC!
App RC4 changelog:
- Prevented ESx/E users from selecting extra long beep (doesn't exist on those platforms)
- Prevented CamiBLE users from changing dash display options
- Added new controls for platform specific temperature sensors, cruise control off beep and current raising
- Prevented smooth brains from using speed-based throttle without a speed limit set (smh)
- Show when spoofed legacy CFW is detected
- Added the contributions list (finally)
- Fixed general I/O stability (that "Index data error" when flashing ends should be gone)
- Better checks to ensure SHFW is actually installed after flashing
- Fixed automation that would trigger anytime you'd visit the Info tab
- Automatically switch to info tab after flashing (that way SHFW tab switch isn't buggy anymore lmao)
- Added tooltip bubbles to the app (including SHFW)
