Infos zum neuen Ninebot P65D
Here we are
Currently there are two methods working (on mine scooter at least) :
THE FIRST WAY
via chinese app, apparently the same one as founded in the web (which doesn't work) last weeks but, with some slightly graphics differences and overall, different codes. With this app you can unlock the full speed: after inserted the code, the scooter confirm with two beep and after restarting the word "sport" into the display became red and you can reach 40kmh.
Options available in the segway app remaining the same.
THE SECOND WAY
change the serial number, via downG app, you need to create a new segway account (you can just log out by the older) and register your device with the new modified serial (find vehicle will recognize your device as a new one) you will get an original US device with all option enabled, cruise control, park mode, all settings for speed enabled. The maximum speed available will be 32kmh, the option "boost speed" remain unavailable.
I'm still in testing mode but I'm pretty sure that if you apply the first way and then the second, you will get ALL OPTIONS WITH FULL SPEED
The only doubt, repeating, is the version of my scooter "E" by yours "D" but as my results it shouldn't make any differences and it's worth to make a try.
That is what I've done.
Hope I had been pretty clear, it's hard to explain with the right words but it's very simply and safe to apply. For any questions I'm still here.
if you are interested I can find a way to upload application and codes. Greets
Here are an attachment with the final results (wheels lifted up obviously 😁)
Reaktionen: iEScooter
Here we are
THE FIRST WAY
THE SECOND WAY
Sorry aber ich kann mich da nur wiederholen es funktioniert alles nicht mit einem Ninebot P65D !
Ich selber habe alles getestet und ausprobiert aber z.b. mit downG kann man nicht sie Seriennummer ändern der roller piept 3x und es ändert sich nichts!
(SN an 4 stelle geändert N)
Reaktionen: Christech
Entschuldigung, ich habe meine Methode beschrieben, das heißt nicht, dass sie für alle funktioniert!
Ja verstehe das schon aber ich möchte nur informieren das es mit einem P65D nicht funktioniert und ich rate auch erstmal ab die original app zu verwenden
Und in deiner Beschreibung erwähntest du es!
Und hier geht es ja um den P65D!
Diese ist meine App und meine Codes für diejenigen, die es versuchen möchten. Achtung: kopieren Sie nur den text ohne formatierung, leerzeichen oder sonstiges, sonst wird der vorgang ungültig!
Click here
Was hast du davon hier dauern Methoden zu erläutern die nicht funktionieren?
Hier geht es ja um den P65D
Und deine Methode funktioniert nicht bei einem P65D!!
Ob es an andere Modelle funktioniert kann ich nicht sagen!
Ich verdiene nichts, ich wurde gebeten, die Methode zu erklären, und das tue ich. Wissen Sie, was das Wort „Höflichkeit“ bedeutet?
Der User hat doch gesagt, dass seine Lösung für ein P65E ist.
Der P65D hat mit Sicherheit die gleiche Sperre drin wie der G30D oder andere Ninebots die man nicht mehr Tunen kann.
Das würde auch das verhalten erklären, wenn man dem P65D eine SN schickt.
Bin mal gespannt, ob die anderen Länder auch so rumheulen wegen Tunen und mehr als 25km/h :LOL:
  • Strahlend
Reaktionen: Zengan und iEScooter
Ich kenne das Wort Höflichkeit sehr gut sogar!
Verstehe aber jetzt diese Frage nicht was bringt das?
Bitte unterlasse es doch einfach falsche Anleitung für einen P65D zu verbreiten!!
Ps: vom verdienen habe ich doch überhaupt nicht gesprochen obwohl ich das jetzt einen guten aspekt drinne sehe !
Nein er hat eine andere sperre die Probleme macht das NFC!!
Und ich selber habe hier am p65D getestet !
Das ist doch das gleiche verhalten wie beim G30D der eine "Tuning Sperre" drin hat.
Das piepen bedeutet, BLE hat Daten Empfangen. Bedeutet alles richtig aber Tuning Sperre ist drin.
Nee nicht ganz habe woanders gelesen wo sich auch welche mit befassen das ein Problem auch die NFC sperre ist ob es jetzt wirklich so ist kann ich nicht sagen!
Aber anscheinend ist es nicht so wie beim G30 sonst würde es doch schon längst gehen.
