Nach Dashboard Tausch - Ready für VLT
Ich vermute du meinst die Log Datei, da ich sie nicht als Datei angehangen bekomme kopiere ich den Text mal manuell:
Code:
MIDUMAIN 29-07-2022_09-06-44 device=Dashboard  action=Downgrade   scooter=1s chip=N51822x
MIDUMAIN working dir=C:\Users\caro\Desktop\Scooter tuning\MiDu-Flasher_v1.0.5\Resource\
:MIDUDOWN 29-07-2022_09-07-03 "https://files.scooterhacking.org/firmware/1s/BLE/BLE134.bin" "files\BLE\App\N51822x\1s\App.bin"
:MIDUDOWN 29-07-2022_09-08-33 "https://github.com/CamiAlfa/stlink_m365_BLE/raw/master/flashing/bootldr.bin" "files\BLE\Bootloader\Bootloader_1s_Pro2_Mi3.bin"
:MIDUSPOOF 29-07-2022_09-09-26
:MIDUSPOOF 29-07-2022_09-09-26 done, spoofed successfully "files\BLE\App\N51822x\1s\AppSpoofed.bin" to 157 at offset=0x3E44
OCDINIT 29-07-2022_09-14-21
Open On-Chip Debugger 0.11.0+dev-00626-g92c4e634d (2022-03-19-11:44)
Licensed under GNU GPL v2
For bug reports, read
    http://openocd.org/doc/doxygen/bugs.html
Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'.
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
Info : clock speed 1000 kHz
Info : STLINK V2J37S7 (API v2) VID:pID 0483:3748
Info : Target voltage: 3.272000
Error: init mode failed (unable to connect to the target)
ERROR :OCDINIT 29-07-2022_09-14-24 no Connection, errors=1 speed=1000
OCDINIT 29-07-2022_09-14-29
Info : Target voltage: 3.270400
ERROR :OCDINIT 29-07-2022_09-14-31 no Connection, errors=2 speed=1000
OCDINIT 29-07-2022_09-14-36
ERROR :OCDINIT 29-07-2022_09-14-38 no Connection, errors=3 speed=1000
OCDINIT 29-07-2022_09-14-43
ERROR :OCDINIT 29-07-2022_09-14-45 no Connection, errors=4 speed=1000
OCDINIT 29-07-2022_09-14-50
ERROR :OCDINIT 29-07-2022_09-14-52 no Connection, errors=5 speed=1000
OCDINIT 29-07-2022_09-14-57
Info : clock speed 400 kHz
Info : Target voltage: 3.268800
ERROR :OCDINIT 29-07-2022_09-14-59 no Connection, errors=6 speed=400
OCDINIT 29-07-2022_09-15-04
Info : [nrf51.cpu] Cortex-M0 r0p0 processor detected
Info : [nrf51.cpu] target has 4 breakpoints, 2 watchpoints
Info : starting gdb server for nrf51.cpu on 3333
Info : Listening on port 3333 for gdb connections
target halted due to debug-request, current mode: Thread
xPSR: 0xc1000000 pc: 0x000006d0 msp: 0x000007c0
OCDDUMP 29-07-2022_09-15-07
Info : STLINK V2J29S7 (API v2) VID:pID 0483:3748
dumped 1024 bytes in 0.062400s (16.026 KiB/s)
OCDINIT 29-07-2022_09-15-09
OCDDUMP 29-07-2022_09-15-11
OCDINIT 29-07-2022_09-15-13
OCDEXPDUMP 29-07-2022_09-15-14
OCDINIT 29-07-2022_09-16-54
OCDERASE 29-07-2022_09-16-55
Info : nRF51822-xxxx(build code: xx) 256kB Flash, 32kB RAM
Info : Mass erase completed.
Info : A reset or power cycle is required if the flash was protected before.
OCDINIT 29-07-2022_09-16-56
xPSR: 0xc1000000 pc: 0xfffffffe msp: 0xfffffffc
OCDWRITE 29-07-2022_09-16-56
** Programming Started **
Info : Flash write discontinued at 0x000007c0, next section at 0x00001000
Warn : Adding extra erase range, 0x000007c0 .. 0x000007ff
Warn : Adding extra erase range, 0x0001afe0 .. 0x0001afff
** Programming Finished **
** Verify Started **
** Verified OK **
OCDINIT 29-07-2022_09-17-11
OCDWRITE 29-07-2022_09-17-14
Warn : Adding extra erase range, 0x00028ab4 .. 0x00028bff
** Verified OK **
OCDINIT 29-07-2022_09-17-22
OCDWRITE 29-07-2022_09-17-25
Warn : Adding extra erase range, 0x0003b900 .. 0x0003bbff
** Verified OK **
OCDINIT 29-07-2022_09-17-27
OCDWRITE 29-07-2022_09-17-29
** Verified OK **
OCDINIT 29-07-2022_09-17-33
OCDWRITE 29-07-2022_09-17-35
Warn : Adding extra erase range, 0x10001020 .. 0x100013ff
** Verified OK **
OCDRESET 29-07-2022_09-17-38
Resource\MiDu-Flasher.bat 29-07-2022_09-17-40
Mod edit: Code tags
Nee ich meinte eigentlich genau das was ich auch geschrieben hatte.
Aber gut das wir das geklärt haben. 😂
Der Downgrade war laut Log schonmal erfolgreich.
Und bitte wenn logs oder dergleichen gepostet werden, in einem code spoiler posten.
code_spioler_rp-png.19047
Oder als zip Archiv an den Post anhängen.
Dann ist das ned so eine Text Wall.:oops:
Jetzt fehlt nur noch die Params und info.txt aus deiner zip datei die du zum flashen via downg nutzt.
Sorry, hoffe jetzt ist das Format richtig:
Code:
dev: 1s;
nam: VLT319;
enc: B;
typ: DRV;
md5: f68e63ad2cbf41eba3d6b7d48246761e;
md5e: bbe9f8e0fa5b1aed8dd4b802158eea15;
Code:
- Version: DRV319;
This file has been generated from VLT_Zipper 2 powered by XiaoTea. Make sure you know what it contains.;
Changes below;
Offset | Vanilla | Mod;
Vergleichen der Dateien C:\USERS\CARO\DESKTOP\SCOOTER TUNING\VLT-ZIPPER2\RESOURCE\BIN\FIRMWARES\DRV319.bin und C:\USERS\CARO\DESKTOP\DRV319.BIN
00005D14: 19 1B
00005EAA: 42 4F
00005EAC: 6E FF
00005EAD: 0C 7C
Ich hoffe das hilft, viele Grüße
Ja, sieht alles gut aus soweit.
27Kmh (GM) und Autom. abbrems Mod richtig drin.
Probier mal bitte mit SHU v2.0.3 zu flashen.
Du musst nach SHU 2.0.3 googeln weil die aktuelle 2.0.4 das flashen mit gespoofter BLE nicht zu lässt.
Du hast ja gespooft wie ich das aus der MiDu Log sehe.
Was ja prinzipiell gut ist, aber dann musst du eben eine ältere SHU zum flashen nehmen.
Nun fragt MiDu-Flasher ob die neue BLE auf 157 (Pro2/1s) oder 155 (Mi3) gespooft werden soll.
Spoofen bedeutet hier, das die Versionsnummer der BLE die heruntergeladen wurde auf 157 bzw 155 geändert werden soll.
Es ist empfohlen diese Frage mit ( y ) also ja zu bestätigen.
Somit schaut es nach dem Downgrade so aus, als ob immer noch eine BLE157/155 drauf ist.
Allerdings muss ich auch erwähnen, das mit der neuesten SHU App (2.0.4) das Flashen dann nicht mehr funktioniert.
Die neuste Version der SHU App verweigert dann das Flashen der BLE und DRV.
Das ist natürlich nur eine falsche Annahme von SHU, aber es wurde leider so in die neuste SHU Version eingebaut.
Mit Downg, oder einer älteren SHU Version (z.b. 2.0.3 und darunter), können aber trotzdem wie gewohnt BLE's und DRV's geflasht werden.
Okay das sind doch schon mal gute Neuigkeiten, dass die zip Datei soweit okay ist.
Ich habe es jetzt noch einmal mit Downg versucht und während des Flashens kurz vor 50% mal den button gedrückt, weil ich das Gefühl hatte dass der Roller sich wegen fehlender Aktivität sonst ausschaltet.
Tatsächlich läuft der Flash dann bis zum Ende durch und zeigt auch "done" an. Allerdings bleibt die Geschwindigkeit bei 20 km/h, sieht also so aus als hätte es nicht geklappt.
Die Idee mit der SHU 2.0.3. hatte ich auch schon. Den Scooter kann ich damit zwar auch connecten und mittels "load from file" auch die zip auswählen, allerdings wird die Datei scheinbar nicht angenommen. Wenn ich dann auf "flash" tippe, passiert absolut gar nichts, als wäre keine Datei ausgewählt worden.
Naja also wenn du diese VLT geflasht hast aus der die Params.txt stammt, dann sollte das so stimmen.
Du hast ja nur den GM Sport modus auf 27Kmh gepatcht und nicht den DE Sport modus.
Schau mal nochmal in den ersten Beitrag von VLT-Firmwares rein.
Da wird das eigentlich recht gut erklärt alles.
Ggf. auch den Abschnitt "Abkürzungen und Begriffserklärungen" dort mal lesen.
Ach ich Depp, jetzt sehe ich es: hinter dem 27km/h mod steht ja in Klammern (GM/LGTM).
Da ich ja das Android Handy nur zum Flashen benutze und deshalb keine App zum Ein-/Ausschalten des LTGM mods nutzen werde, benötige ich also zusätzlich zu meinen bisherigen Anpassungen nur noch den LTGM persistent mod, richtig? (Sport Modus 27km/h soll einfach immer aktiv sein)
Versuche das Ganze dann gleich noch mal in DownG zu schmeißen und werde euch berichten.
Kannst relight nehmen wenn du ohne Handy ltgm aktivieren möchtest.
So, nun ist aber gut mit dem privat Support hier.😅
Alles weitere bitte selbst recherchieren.
Dankeschön. ❤
Brauchst nicht.
Der Thread kann zu.
Alles geklärt.
Sogar die Dinge die eigentlich in andere threads gehören😉
Reaktionen: Olli_69
