MIDUMAIN 28-10-2022_16-24-04 device=Dashboard action=Downgrade scooter=Pro2 chip=N51822x
MIDUMAIN working dir=C:\Users\nils-\OneDrive\Desktop\MiDu-Flasher_v1.0.5\Resource\
:MIDUDOWN 28-10-2022_16-24-13 "https://files.scooterhacking.org/firmware/pro2/BLE/BLE134.bin" "files\BLE\App\N51822x\Pro2\App.bin"
:MIDUDOWN 28-10-2022_16-24-41 "https://github.com/CamiAlfa/stlink_m365_BLE/raw/master/flashing/bootldr.bin" "files\BLE\Bootloader\Bootloader_1s_Pro2_Mi3.bin"
:MIDUSPOOF 28-10-2022_16-27-13
:MIDUSPOOF 28-10-2022_16-27-13 done, spoofed successfully "files\BLE\App\N51822x\Pro2\AppSpoofed.bin" to 157 at offset=0x3E44
OCDINIT 28-10-2022_16-35-20
Open On-Chip Debugger 0.11.0+dev-00626-g92c4e634d (2022-03-19-11:44)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'.
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
Info : clock speed 1000 kHz
Info : STLINK V2J37S7 (API v2) VID:PID 0483:3748
Info : Target voltage: 3.158220
Error: init mode failed (unable to connect to the target)
ERROR :OCDINIT 28-10-2022_16-35-22 no Connection, errors=1 speed=1000
OCDINIT 28-10-2022_16-35-27
Info : Target voltage: 3.164410
ERROR :OCDINIT 28-10-2022_16-35-28 no Connection, errors=2 speed=1000
OCDINIT 28-10-2022_16-35-33
ERROR :OCDINIT 28-10-2022_16-35-33 no Connection, errors=3 speed=1000
OCDINIT 28-10-2022_16-35-38
ERROR :OCDINIT 28-10-2022_16-35-38 no Connection, errors=4 speed=1000
OCDINIT 28-10-2022_16-35-43
ERROR :OCDINIT 28-10-2022_16-35-43 no Connection, errors=5 speed=1000
OCDINIT 28-10-2022_16-35-48
Info : clock speed 400 kHz
Info : [nrf51.cpu] Cortex-M0 r0p0 processor detected
Info : [nrf51.cpu] target has 4 breakpoints, 2 watchpoints
Info : starting gdb server for nrf51.cpu on 3333
Info : Listening on port 3333 for gdb connections
target halted due to debug-request, current mode: Thread
xPSR: 0xc1000000 pc: 0x000006d0 msp: 0x000007c0
OCDDUMP 28-10-2022_16-35-49
Info : STLINK V2J29S7 (API v2) VID:PID 0483:3748
Info : Target voltage: 3.162863
dumped 1024 bytes in 0.053870s (18.563 KiB/s)
OCDINIT 28-10-2022_16-35-50
OCDDUMP 28-10-2022_16-35-50
dumped 1024 bytes in 0.053363s (18.740 KiB/s)
OCDEXPDUMP 28-10-2022_16-35-50
OCDINIT 28-10-2022_16-36-11
Info : Target voltage: 3.161315
OCDERASE 28-10-2022_16-36-11
Info : nRF51822-xxxx(build code: xx) 256kB Flash, 32kB RAM
Info : Mass erase completed.
Info : A reset or power cycle is required if the flash was protected before.
xPSR: 0xc1000000 pc: 0xfffffffe msp: 0xfffffffc
OCDWRITE 28-10-2022_16-36-12
** Programming Started **
Info : Flash write discontinued at 0x000007c0, next section at 0x00001000
Warn : Adding extra erase range, 0x000007c0 .. 0x000007ff
Warn : Adding extra erase range, 0x0001afe0 .. 0x0001afff
** Programming Finished **
** Verify Started **
** Verified OK **
OCDINIT 28-10-2022_16-36-22
OCDWRITE 28-10-2022_16-36-23
Warn : Adding extra erase range, 0x00028ab0 .. 0x00028bff
** Verified OK **
OCDINIT 28-10-2022_16-36-28
OCDWRITE 28-10-2022_16-36-29
Warn : Adding extra erase range, 0x0003b900 .. 0x0003bbff
** Verified OK **
OCDINIT 28-10-2022_16-36-29
** Verified OK **
OCDINIT 28-10-2022_16-36-31
OCDWRITE 28-10-2022_16-36-31
Warn : Adding extra erase range, 0x10001020 .. 0x100013ff
** Verified OK **
OCDRESET 28-10-2022_16-36-32
Resource\MiDu-Flasher.bat 28-10-2022_16-36-33
MIDUMAIN 31-10-2022_10-30-19 device=Dashboard action=Downgrade scooter=Pro2 chip=N51822x
OCDINIT 31-10-2022_10-31-41
Info : Target voltage: 3.157650
ERROR :OCDINIT 31-10-2022_10-31-45 no Connection, errors=1 speed=1000
OCDINIT 31-10-2022_10-31-52
Info : Target voltage: 3.168496
ERROR :OCDINIT 31-10-2022_10-31-52 no Connection, errors=2 speed=1000
OCDINIT 31-10-2022_10-31-57
Info : Target voltage: 3.166946
ERROR :OCDINIT 31-10-2022_10-31-58 no Connection, errors=3 speed=1000
OCDINIT 31-10-2022_10-32-03
ERROR :OCDINIT 31-10-2022_10-32-03 no Connection, errors=4 speed=1000
OCDINIT 31-10-2022_10-32-08
ERROR :OCDINIT 31-10-2022_10-32-08 no Connection, errors=5 speed=1000
OCDINIT 31-10-2022_10-32-13
OCDDUMP 31-10-2022_10-32-14
dumped 1024 bytes in 0.052325s (19.111 KiB/s)
OCDINIT 31-10-2022_10-32-15
OCDDUMP 31-10-2022_10-32-15
dumped 1024 bytes in 0.053140s (18.818 KiB/s)
OCDDUMP 31-10-2022_10-32-16
dumped 256 bytes in 0.013947s (17.925 KiB/s)
OCDINIT 31-10-2022_10-32-16
OCDERASE 31-10-2022_10-32-16
ERROR :OCDERASE 31-10-2022_10-32-16 no Connection, errors=6 speed=400
OCDINIT 31-10-2022_10-32-21
ERROR :OCDINIT 31-10-2022_10-32-21 no Connection, errors=7 speed=400
OCDINIT 31-10-2022_10-32-27
ERROR :OCDINIT 31-10-2022_10-32-27 no Connection, errors=8 speed=400
OCDINIT 31-10-2022_10-32-32
ERROR :OCDINIT 31-10-2022_10-32-32 no Connection, errors=9 speed=400
OCDINIT 31-10-2022_10-32-37
ERROR :OCDINIT 31-10-2022_10-32-37 no Connection, errors=10 speed=400
OCDINIT 31-10-2022_10-32-42
ERROR :OCDINIT 31-10-2022_10-32-42 no Connection, errors=11 speed=400
OCDINIT 31-10-2022_10-32-48
ERROR :OCDINIT 31-10-2022_10-32-48 no Connection, errors=12 speed=400
OCDINIT 31-10-2022_10-32-53
Info : Target voltage: 3.165397
ERROR :OCDINIT 31-10-2022_10-32-53 no Connection, errors=13 speed=400
OCDINIT 31-10-2022_10-32-58
ERROR :OCDINIT 31-10-2022_10-32-58 no Connection, errors=14 speed=400
OCDINIT 31-10-2022_10-33-04
ERROR :OCDINIT 31-10-2022_10-33-04 no Connection, errors=15 speed=400
OCDINIT 31-10-2022_10-33-10
ERROR :OCDINIT 31-10-2022_10-33-10 no Connection, errors=16 speed=400
OCDINIT 31-10-2022_10-33-15
ERROR :OCDINIT 31-10-2022_10-33-15 no Connection, errors=17 speed=400
OCDINIT 31-10-2022_10-33-20
ERROR :OCDINIT 31-10-2022_10-33-20 no Connection, errors=18 speed=400
OCDINIT 31-10-2022_10-33-25
ERROR :OCDINIT 31-10-2022_10-33-26 no Connection, errors=19 speed=400
OCDINIT 31-10-2022_10-33-31
ERROR :OCDINIT 31-10-2022_10-33-31 no Connection, errors=20 speed=400
OCDINIT 31-10-2022_10-33-36
Info : clock speed 100 kHz
OCDRESET 31-10-2022_10-33-37
OCDINIT 31-10-2022_10-33-38
OCDWRITE 31-10-2022_10-33-38
Error: Flash sector 0 is protected
Error: failed erasing sectors 0 to 1
embedded:startup.tcl:1162: Error: ** Programming Failed **
in procedure 'program'
in procedure 'program_error' called at file "embedded:startup.tcl", line 1227
at file "embedded:startup.tcl", line 1162
ERROR :OCDWRITE 31-10-2022_10-33-39 no Connection, errors=21 speed=100
OCDINIT 31-10-2022_10-33-44
OCDWRITE 31-10-2022_10-33-45
ERROR :OCDWRITE 31-10-2022_10-33-46 no Connection, errors=22 speed=100
OCDINIT 31-10-2022_10-33-51
OCDWRITE 31-10-2022_10-33-52
ERROR :OCDWRITE 31-10-2022_10-33-53 no Connection, errors=23 speed=100
OCDINIT 31-10-2022_10-33-58
ERROR :OCDINIT 31-10-2022_10-33-58 no Connection, errors=24 speed=100
OCDINIT 31-10-2022_10-34-03
ERROR :OCDINIT 31-10-2022_10-34-03 no Connection, errors=25 speed=100
OCDINIT 31-10-2022_10-34-08
OCDWRITE 31-10-2022_10-34-10
ERROR :OCDWRITE 31-10-2022_10-34-10 no Connection, errors=26 speed=100
OCDINIT 31-10-2022_10-34-15
OCDWRITE 31-10-2022_10-34-17
ERROR :OCDWRITE 31-10-2022_10-34-17 no Connection, errors=27 speed=100
OCDINIT 31-10-2022_10-34-22
ERROR :OCDINIT 31-10-2022_10-34-23 no Connection, errors=28 speed=100
OCDINIT 31-10-2022_10-34-28
ERROR :OCDINIT 31-10-2022_10-34-28 no Connection, errors=29 speed=100
OCDINIT 31-10-2022_10-34-33
ERROR :OCDINIT 31-10-2022_10-34-33 no Connection, errors=30 speed=100
OCDINIT 31-10-2022_10-34-39
ERROR :OCDINIT 31-10-2022_10-34-39 no Connection, errors=31 speed=100
OCDINIT 31-10-2022_10-35-19
ERROR :OCDINIT 31-10-2022_10-35-20 no Connection, errors=32 speed=100
OCDINIT 31-10-2022_10-35-25
OCDWRITE 31-10-2022_10-35-26
ERROR :OCDWRITE 31-10-2022_10-35-27 no Connection, errors=33 speed=100
OCDINIT 31-10-2022_10-35-32
OCDWRITE 31-10-2022_10-35-33
ERROR :OCDWRITE 31-10-2022_10-35-34 no Connection, errors=34 speed=100
OCDINIT 31-10-2022_10-35-39
ERROR :OCDINIT 31-10-2022_10-35-39 no Connection, errors=35 speed=100
OCDINIT 31-10-2022_10-35-44
OCDWRITE 31-10-2022_10-35-45
ERROR :OCDWRITE 31-10-2022_10-35-46 no Connection, errors=36 speed=100
OCDINIT 31-10-2022_10-35-51
OCDWRITE 31-10-2022_10-35-52
ERROR :OCDWRITE 31-10-2022_10-35-53 no Connection, errors=37 speed=100
OCDINIT 31-10-2022_10-35-58
OCDWRITE 31-10-2022_10-35-59
ERROR :OCDWRITE 31-10-2022_10-36-00 no Connection, errors=38 speed=100
OCDINIT 31-10-2022_10-36-06
OCDWRITE 31-10-2022_10-36-08
ERROR :OCDWRITE 31-10-2022_10-36-08 no Connection, errors=39 speed=100
OCDINIT 31-10-2022_10-36-13
OCDWRITE 31-10-2022_10-36-15
ERROR :OCDWRITE 31-10-2022_10-36-15 no Connection, errors=40 speed=100
OCDINIT 31-10-2022_10-36-20
OCDWRITE 31-10-2022_10-36-22
ERROR :OCDWRITE 31-10-2022_10-36-22 no Connection, errors=41 speed=100
OCDINIT 31-10-2022_10-36-27
OCDWRITE 31-10-2022_10-36-28
ERROR :OCDWRITE 31-10-2022_10-36-29 no Connection, errors=42 speed=100
OCDINIT 31-10-2022_10-36-34
OCDWRITE 31-10-2022_10-36-35
ERROR :OCDWRITE 31-10-2022_10-36-36 no Connection, errors=43 speed=100
OCDINIT 31-10-2022_10-36-41
OCDWRITE 31-10-2022_10-36-42
ERROR :OCDWRITE 31-10-2022_10-36-43 no Connection, errors=44 speed=100
OCDINIT 31-10-2022_10-36-48
OCDWRITE 31-10-2022_10-36-49
ERROR :OCDWRITE 31-10-2022_10-36-50 no Connection, errors=45 speed=100
OCDINIT 31-10-2022_10-36-55
OCDWRITE 31-10-2022_10-36-56
ERROR :OCDWRITE 31-10-2022_10-36-57 no Connection, errors=46 speed=100
OCDINIT 31-10-2022_10-37-02
ERROR :OCDINIT 31-10-2022_10-37-02 no Connection, errors=47 speed=100
OCDINIT 31-10-2022_10-37-07
ERROR :OCDINIT 31-10-2022_10-37-08 no Connection, errors=48 speed=100
OCDINIT 31-10-2022_10-37-13
ERROR :OCDINIT 31-10-2022_10-37-13 no Connection, errors=49 speed=100
OCDINIT 31-10-2022_10-37-18
ERROR :OCDINIT 31-10-2022_10-37-19 no Connection, errors=50 speed=100
OCDINIT 31-10-2022_10-37-24
ERROR :OCDINIT 31-10-2022_10-37-24 no Connection, errors=51 speed=100
