MIDUMAIN 22-04-2024_21-44-00 device=Dashboard action=Write Flash scooter=Pro2 chip=N51822x
MIDUMAIN working dir=C:\Users\StefaN\Downloads\MiDu-Flasher_v1.0.50000\MiDu-Flasher_v1.0.5\Resource\
OCDINIT 22-04-2024_21-44-00
Open On-Chip Debugger 0.11.0+dev-00626-g92c4e634d (2022-03-19-11:44)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'.
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
Info : clock speed 1000 kHz
Info : STLINK V2J37S7 (API v2) VID:PID 0483:3748
Info : Target voltage: 3.246684
Error: init mode failed (unable to connect to the target)
ERROR :OCDINIT 22-04-2024_21-44-00 no Connection, errors=1 speed=1000
OCDINIT 22-04-2024_21-44-05
Info : Target voltage: 3.245093
ERROR :OCDINIT 22-04-2024_21-44-06 no Connection, errors=2 speed=1000
OCDINIT 22-04-2024_21-44-11
Info : Target voltage: 3.241910
ERROR :OCDINIT 22-04-2024_21-44-11 no Connection, errors=3 speed=1000
OCDINIT 22-04-2024_21-44-16
ERROR :OCDINIT 22-04-2024_21-44-16 no Connection, errors=4 speed=1000
OCDINIT 22-04-2024_21-44-21
ERROR :OCDINIT 22-04-2024_21-44-22 no Connection, errors=5 speed=1000
OCDINIT 22-04-2024_21-44-27
Info : clock speed 400 kHz
Info : [nrf51.cpu] Cortex-M0 r0p0 processor detected
Info : [nrf51.cpu] target has 4 breakpoints, 2 watchpoints
Info : starting gdb server for nrf51.cpu on 3333
Info : Listening on port 3333 for gdb connections
target halted due to debug-request, current mode: Thread
xPSR: 0xc1000000 pc: 0x000006d0 msp: 0x000007c0
OCDERASE 22-04-2024_21-44-28
Info : Target voltage: 3.249867
Info : nRF51822-xxxx(build code: xx) 256kB Flash, 32kB RAM
Info : Mass erase completed.
Info : A reset or power cycle is required if the flash was protected before.
OCDINIT 22-04-2024_21-44-28
Info : Target voltage: 3.251459
xPSR: 0xc1000000 pc: 0xfffffffe msp: 0xfffffffc
OCDWRITE 22-04-2024_21-44-29
** Programming Started **
Info : Flash write discontinued at 0x000007c0, next section at 0x00001000
Warn : Adding extra erase range, 0x000007c0 .. 0x000007ff
Warn : Adding extra erase range, 0x0001afe0 .. 0x0001afff
** Programming Finished **
** Verify Started **
** Verified OK **
OCDINIT 22-04-2024_21-44-39
OCDWRITE 22-04-2024_21-44-40
Warn : Adding extra erase range, 0x00028ab0 .. 0x00028bff
** Verified OK **
OCDINIT 22-04-2024_21-44-45
Info : Target voltage: 3.240318
OCDWRITE 22-04-2024_21-44-46
** Verified OK **
OCDINIT 22-04-2024_21-44-48
Info : Target voltage: 3.248276
OCDWRITE 22-04-2024_21-44-48
Warn : Adding extra erase range, 0x10001020 .. 0x100013ff
** Verified OK **
OCDRESET 22-04-2024_21-44-48
ERROR :OCDRESET 22-04-2024_21-44-49 no Connection, errors=6 speed=400
OCDRESET 22-04-2024_21-44-54
Info : Target voltage: 3.243501
"C:\Users\StefaN\Downloads\MiDu-Flasher_v1.0.50000\MiDu-Flasher_v1.0.5\Resource\MiDu-Flasher.bat" 22-04-2024_21-44-55
