target halted due to debug-request, current mode: Thread
xPSR: 0xc1000000 pc: 0xfffffffe msp: 0xfffffffc
** Programming Started **
Info : nRF51822-xxxx(build code: xx) 256kB Flash, 32kB RAM
Info : Flash write discontinued at 0x000007c0, next section at 0x00001000
Warn : Adding extra erase range, 0x000007c0 .. 0x000007ff
Warn : Adding extra erase range, 0x0001afe0 .. 0x0001afff
** Programming Finished **
** Verify Started **
** Verified OK **
OCDINIT 05-07-2022_17-56-29
Open On-Chip Debugger 0.11.0+dev-00626-g92c4e634d (2022-03-19-11:44)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : clock speed 100 kHz
Info : STLINK V2J37S7 (API v2) VID:PID 0483:3748
Info : Target voltage: 3.136434
Info : [nrf51.cpu] Cortex-M0 r0p0 processor detected
Info : [nrf51.cpu] target has 4 breakpoints, 2 watchpoints
Info : starting gdb server for nrf51.cpu on 3333
Info : Listening on port 3333 for gdb connections
xPSR: 0xc1000000 pc: 0x000006d0 msp: 0x000007c0
OCDWRITE 05-07-2022_17-56-29
Info : Target voltage: 3.141085
Warn : Adding extra erase range, 0x00028ab4 .. 0x00028bff
** Verified OK **
OCDINIT 05-07-2022_17-56-41
Info : Target voltage: 3.139535
OCDWRITE 05-07-2022_17-56-41
Warn : Adding extra erase range, 0x0003b900 .. 0x0003bbff
** Verified OK **
OCDINIT 05-07-2022_17-56-42
OCDWRITE 05-07-2022_17-56-43
** Verified OK **
OCDINIT 05-07-2022_17-56-46
OCDWRITE 05-07-2022_17-56-46
Info : Target voltage: 3.134884
Warn : Adding extra erase range, 0x10001020 .. 0x100013ff
** Verified OK **
OCDRESET 05-07-2022_17-56-48
Info : Target voltage: 3.137984
Resource\MiDu-Flasher.bat 05-07-2022_17-56-49
