[ReFlasher] Starting..
Info : clock speed 1000 kHz
Info : STLINK V2J37S7 (API v2) VID
ID 0483:3748
[ReFlasher] Found ST-Link
Info : Target voltage: 3.258863
Info : stm32f1x.cpu: hardware has 6 breakpoints, 4 watchpoints
[ReFlasher] Connected to target
Info : starting gdb server for stm32f1x.cpu on 3333
Info : Listening on port 3333 for gdb connections
target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x08000120 msp: 0x20000550
Info : device id = 0x20036410
Warn : STM32 flash size failed, probe inaccurate - assuming 128k flash
Info : flash size = 128kbytes
flash 'stm32f1x' found at 0x08000000
stm32x unlocked.
[ReFlasher] Disabled RDP
INFO: a reset or power cycle is required for the new settings to take effect.
xPSR: 0x01000000 pc: 0xfffffffe msp: 0xfffffffc
stm32x mass erase complete
[ReFlasher] Erased chip
dumped 12 bytes in 0.001354s (8.655 KiB/s)
[ReFlasher] Got UID for activation
[ReFlasher] Generated user data page
[ReFlasher] Writing to chip
ID 0483:3748
Info : Target voltage: 3.234783
stm32x unlocked.
wrote 3104 bytes from file C:\Program Files (x86)\ScooterHacking ReFlasher\binaries\bootloader\nb_DRV.bin to flash bank 0 at offset 0x00000000 in 0.165475s (18.318 KiB/s)
[ReFlasher] Wrote bootloader
wrote 35492 bytes from file C:\Program Files (x86)\ScooterHacking ReFlasher\binaries\firmware\g30_DRV.bin to flash bank 0 at offset 0x00001000 in 1.124784s (30.815 KiB/s)
[ReFlasher] Wrote firmware
wrote 1024 bytes from file C:\Users\activ\AppData\Roaming\reflasher\binaries\temp\drv_user_data.bin to flash bank 0 at offset 0x0001c000 in 0.086132s (11.610 KiB/s)
[ReFlasher] Wrote userdata
[ReFlasher] All done
