OCDINIT 05-06-2023_17-04-59
Open On-Chip Debugger 0.11.0+dev-00626-g92c4e634d (2022-03-19-11:44)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'.
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
Info : clock speed 100 kHz
Info : STLINK V2J37S7 (API v2) VID:PID 0483:3748
Info : Target voltage: 3.268221
Info : [nrf51.cpu] Cortex-M0 r0p0 processor detected
Info : [nrf51.cpu] target has 4 breakpoints, 2 watchpoints
Info : starting gdb server for nrf51.cpu on 3333
Info : Listening on port 3333 for gdb connections
target halted due to debug-request, current mode: Thread
xPSR: 00000000 pc: 00000000 msp: 00000000
Error executing event reset-end on target nrf51.cpu:
embedded:startup.tcl:854: Error:
in procedure 'ocd_process_reset'
in procedure 'ocd_process_reset_inner' called at file "embedded:startup.tcl", line 854
Error: jtag status contains invalid mode value - communication failure
Polling target nrf51.cpu failed, trying to reexamine
Examination failed, GDB will be halted. Polling again in 100ms
OCDDUMP 05-06-2023_17-05-00
Error: init mode failed (unable to connect to the target)
ERROR :OCDDUMP 05-06-2023_17-05-00 no Connection, errors=38 speed=100
OCDINIT 05-06-2023_17-05-06
Info : Target voltage: 3.269820
xPSR: 0xc1000000 pc: 0x000006d0 msp: 0x000007c0
OCDDUMP 05-06-2023_17-05-07
dumped 1024 bytes in 0.133551s (7.488 KiB/s)
OCDINIT 05-06-2023_17-05-07
dumped 1024 bytes in 0.133316s (7.501 KiB/s)
OCDINIT 05-06-2023_17-05-08
OCDEXPDUMP 05-06-2023_17-05-08
MIDUMAIN 05-06-2023_17-07-59 device=Dashboard action=Write Flash scooter=Pro2 chip=N51822x
MIDUMAIN working dir=C:\Users\jonas\Downloads\MiDu-Flasher_v1.0.5\MiDu-Flasher_v1.0.5\Resource\
OCDINIT 05-06-2023_17-07-59
Info : clock speed 1000 kHz
ERROR :OCDINIT 05-06-2023_17-07-59 no Connection, errors=1 speed=1000
OCDINIT 05-06-2023_17-08-04
ERROR :OCDINIT 05-06-2023_17-08-04 no Connection, errors=2 speed=1000
OCDINIT 05-06-2023_17-08-09
ERROR :OCDINIT 05-06-2023_17-08-09 no Connection, errors=3 speed=1000
OCDINIT 05-06-2023_17-08-14
ERROR :OCDINIT 05-06-2023_17-08-14 no Connection, errors=4 speed=1000
OCDINIT 05-06-2023_17-08-20
ERROR :OCDINIT 05-06-2023_17-08-20 no Connection, errors=5 speed=1000
OCDINIT 05-06-2023_17-08-25
Info : clock speed 400 kHz
OCDERASE 05-06-2023_17-08-25
Info : nRF51822-xxxx(build code: xx) 256kB Flash, 32kB RAM
Info : Mass erase completed.
Info : A reset or power cycle is required if the flash was protected before.
OCDINIT 05-06-2023_17-08-26
xPSR: 0xc1000000 pc: 0xfffffffe msp: 0xfffffffc
OCDWRITE 05-06-2023_17-08-26
** Programming Started **
Info : Flash write discontinued at 0x000007c0, next section at 0x00001000
Warn : Adding extra erase range, 0x000007c0 .. 0x000007ff
Warn : Adding extra erase range, 0x0001afe0 .. 0x0001afff
Error: Failed to write to nrf5 flash
Error: error writing to flash at address 0x00000000 at offset 0x00001000
embedded:startup.tcl:1162: Error: ** Programming Failed **
in procedure 'program'
in procedure 'program_error' called at file "embedded:startup.tcl", line 1227
at file "embedded:startup.tcl", line 1162
ERROR :OCDWRITE 05-06-2023_17-08-30 no Connection, errors=6 speed=400
OCDINIT 05-06-2023_17-08-36
ERROR :OCDINIT 05-06-2023_17-08-36 no Connection, errors=7 speed=400
OCDINIT 05-06-2023_17-08-41
OCDWRITE 05-06-2023_17-08-42
Error: error waiting for target flash write algorithm
Error: Failed to enable read-only operation
ERROR :OCDWRITE 05-06-2023_17-08-51 no Connection, errors=8 speed=400
OCDINIT 05-06-2023_17-08-56
ERROR :OCDINIT 05-06-2023_17-08-56 no Connection, errors=9 speed=400
OCDINIT 05-06-2023_17-09-01
ERROR :OCDINIT 05-06-2023_17-09-01 no Connection, errors=10 speed=400
OCDINIT 05-06-2023_17-09-06
OCDWRITE 05-06-2023_17-09-07
** Programming Finished **
** Verify Started **
** Verified OK **
OCDINIT 05-06-2023_17-09-18
OCDWRITE 05-06-2023_17-09-18
Warn : Adding extra erase range, 0x00028ab0 .. 0x00028bff
** Verified OK **
OCDINIT 05-06-2023_17-09-24
OCDWRITE 05-06-2023_17-09-24
** Verified OK **
OCDINIT 05-06-2023_17-09-26
OCDWRITE 05-06-2023_17-09-26
Warn : Adding extra erase range, 0x10001020 .. 0x100013ff
** Verified OK **
OCDRESET 05-06-2023_17-09-26
ERROR :OCDRESET 05-06-2023_17-09-26 no Connection, errors=11 speed=400
OCDRESET 05-06-2023_17-09-32
Resource\MiDu-Flasher.bat 05-06-2023_17-09-32
MIDUMAIN 05-06-2023_17-12-27 device=Dashboard action=Downgrade scooter=Pro2 chip=N51822x
:MIDUSPOOF 05-06-2023_17-12-30
:MIDUSPOOF 05-06-2023_17-12-30 done, spoofed successfully "files\BLE\App\N51822x\Pro2\AppSpoofed.bin" to 157 at offset=0x3E44
OCDINIT 05-06-2023_17-13-05
ERROR :OCDINIT 05-06-2023_17-13-05 no Connection, errors=1 speed=1000
OCDINIT 05-06-2023_17-13-10
ERROR :OCDINIT 05-06-2023_17-13-10 no Connection, errors=2 speed=1000
OCDINIT 05-06-2023_17-13-15
ERROR :OCDINIT 05-06-2023_17-13-15 no Connection, errors=3 speed=1000
OCDINIT 05-06-2023_17-13-20
ERROR :OCDINIT 05-06-2023_17-13-20 no Connection, errors=4 speed=1000
OCDINIT 05-06-2023_17-13-25
ERROR :OCDINIT 05-06-2023_17-13-25 no Connection, errors=5 speed=1000
OCDINIT 05-06-2023_17-13-30
ERROR :OCDINIT 05-06-2023_17-13-30 no Connection, errors=6 speed=400
OCDINIT 05-06-2023_17-13-35
ERROR :OCDINIT 05-06-2023_17-13-36 no Connection, errors=7 speed=400
OCDINIT 05-06-2023_17-13-41
OCDDUMP 05-06-2023_17-13-41
dumped 1024 bytes in 0.055041s (18.168 KiB/s)
OCDINIT 05-06-2023_17-13-42
OCDDUMP 05-06-2023_17-13-42
dumped 1024 bytes in 0.054140s (18.471 KiB/s)
dumped 256 bytes in 0.014948s (16.725 KiB/s)
MIDUMAIN 05-06-2023_17-14-20 device=Dashboard action=Write Flash scooter=Pro2 chip=N51822x
OCDINIT 05-06-2023_17-14-20
ERROR :OCDINIT 05-06-2023_17-14-20 no Connection, errors=1 speed=1000
OCDINIT 05-06-2023_17-14-25
ERROR :OCDINIT 05-06-2023_17-14-25 no Connection, errors=2 speed=1000
OCDINIT 05-06-2023_17-14-30
ERROR :OCDINIT 05-06-2023_17-14-31 no Connection, errors=3 speed=1000
OCDINIT 05-06-2023_17-14-36
ERROR :OCDINIT 05-06-2023_17-14-36 no Connection, errors=4 speed=1000
OCDINIT 05-06-2023_17-14-41
ERROR :OCDINIT 05-06-2023_17-14-41 no Connection, errors=5 speed=1000
OCDINIT 05-06-2023_17-14-46
ERROR :OCDINIT 05-06-2023_17-14-46 no Connection, errors=6 speed=400
OCDINIT 05-06-2023_17-14-51
ERROR :OCDINIT 05-06-2023_17-14-51 no Connection, errors=7 speed=400
OCDINIT 05-06-2023_17-14-56
OCDERASE 05-06-2023_17-14-57
OCDINIT 05-06-2023_17-14-57
OCDWRITE 05-06-2023_17-14-57
Error: Error waiting NVMC_READY: generic flash write/erase error (check protection etc...)
Error: Failed to erase reg: 0x4001e508 val: 0x00001800
Error: Error erasing sector 6
Error: failed erasing sectors 4 to 107
ERROR :OCDWRITE 05-06-2023_17-14-58 no Connection, errors=8 speed=400
OCDINIT 05-06-2023_17-15-03
OCDWRITE 05-06-2023_17-15-04
** Verified OK **
OCDINIT 05-06-2023_17-15-15
