ERROR :OCDINIT 30-08-2023_20-59-53 no Connection, errors=5 speed=1000
OCDINIT 30-08-2023_20-59-58
Open On-Chip Debugger 0.11.0+dev-00626-g92c4e634d (2022-03-19-11:44)
Licensed under GNU GPL v2
For bug reports, read
Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'.
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
Info : clock speed 400 kHz
Info : STLINK V2J37S7 (API v2) VID
ID 0483:3748
Info : Target voltage: 3.123097
Info : [nrf51.cpu] Cortex-M0 r0p0 processor detected
Info : [nrf51.cpu] target has 4 breakpoints, 2 watchpoints
Info : starting gdb server for nrf51.cpu on 3333
Info : Listening on port 3333 for gdb connections
target halted due to debug-request, current mode: Thread
xPSR: 0xc1000000 pc: 0x000006d0 msp: 0x000007c0
OCDERASE 30-08-2023_20-59-59
ID 0483:3748
Info : Target voltage: 3.121548
Info : nRF51822-QFAC(build code: A0) 256kB Flash, 32kB RAM
Info : Mass erase completed.
Info : A reset or power cycle is required if the flash was protected before.
OCDINIT 30-08-2023_20-59-59
ID 0483:3748
xPSR: 0xc1000000 pc: 0xfffffffe msp: 0xfffffffc
OCDWRITE 30-08-2023_21-00-00
ID 0483:3748
** Programming Started **
Info : Flash write discontinued at 0x000007c0, next section at 0x00001000
Warn : Adding extra erase range, 0x000007c0 .. 0x000007ff
Warn : Adding extra erase range, 0x0001afe0 .. 0x0001afff
** Programming Finished **
** Verify Started **
** Verified OK **
OCDINIT 30-08-2023_21-00-11
ID 0483:3748
OCDWRITE 30-08-2023_21-00-12
ID 0483:3748
Warn : Adding extra erase range, 0x00028ab4 .. 0x00028bff
** Verified OK **
OCDINIT 30-08-2023_21-00-18
ID 0483:3748
OCDWRITE 30-08-2023_21-00-18
ID 0483:3748
** Verified OK **
OCDINIT 30-08-2023_21-00-20
ID 0483:3748
Info : Target voltage: 3.118452
OCDWRITE 30-08-2023_21-00-20
ID 0483:3748
Warn : Adding extra erase range, 0x10001020 .. 0x100013ff
** Verified OK **
OCDRESET 30-08-2023_21-00-21
ID 0483:3748
ERROR :OCDRESET 30-08-2023_21-00-22 no Connection, errors=6 speed=400
OCDRESET 30-08-2023_21-00-27
ID 0483:3748
Resource\MiDu-Flasher.bat 30-08-2023_21-00-28
